RCD330 Revers Highline camera - Works!
Hi,
Few months ago i order RCD330plus to replace my old one RCD510, it was nice unit but no navigation at all.  After swap i got some issues - no revers camera, bad MIC quality. I read a lot in this forum and other forums too, but always all you have the same problem - how to get work highline camera with RCD330 unit. Some replace factory camera by 3rd scrap and they where not so happy with that.
I start my project in february and finish in may. I got same messages on revers "Rear view camera system is currently not available". I was thinkig it might be related highline camera modul - i replace it by new one 7n0907441B. BUT STILL SAME. For next i take a external dispaly and connect it to camera module video cable - it works. Video standard is NTSC 480i. For next what the heck is wrong? I take a old mediaplayer WD Live and connect it to external monitor and i get videosignal - NTSC 480i. Mediaplayer supports both PAL and NTSC. Now i connected mediaplayer to RCD330 and it works. So what next? Camera is working, RCD330 is working, but together not. Back in the days i worked in security installation company a had some skils in oldschool videosystem - coax cables, analog cameras - a lot of issues. I remember when camera is video source and  monitor is reciver then reciver must have installed EOL resistor.  I mesured monitor video input resistance and compare it RC330 video input. My external monitar has a 75ohm but RCD330 not. I place a 68 ohm resistor between RCD330 CVBS +/- and it works. Highline camera - bending lines is working.
Hi there,
Can you explain in more detail what you did please? Do you have a signal converter installed RGB - CVBS?
Where did you put the resistor?
I have a 2012 Multivan Highline with the highline camera and just bought a RCD330. Now want to get the camera working.
Thanks!
paulwild and smorrs have reacted to this post.
paulwildsmorrs
Hi,
Sorry for late replay. I have MQB RVC module not PQ46. So i don't need any converter.
You must place 75ohm resistor between RCD330 video input pins and magic happens.
Newest Member: lannycallaway2 · Currently Online: 24 Guests
