FAKRA Adapter needed with booster??
Quote from neil on March 2, 2024, 9:46 amHello - what a minefield this all is!! So now I know there are cloned 330s :)...I have an antenna question.
As I am coming from a UK 2010 Polo, I believe the old unit (310) has twin female fakra and the new 330 has one (hence the twin adapter included?).
However, will this cable bring reception back? I am reading you need a boost cable to retrieve phantom boost where one cable then connects to ignition!!?? I really dont want to lose radio signal so wondered what peoples experience was. Thank you 🙂
Quote from neil on March 4, 2024, 2:14 pmThanks. Your video seems to suggest the exact opposite though. You even put a red cross through the 2-1 adapter although that says not for the 330G. Is that another head unit that's different to the RCD330!!?
Quote from Bernardorfm on July 11, 2026, 8:39 pmthe thing is, if you connect 2 antennas to the same unit, it will create interferente and worst reception.
you need a combiner hardwate before the single fakra output to connected to the radio.https://www.tomzzaudio.de/Double-Fakra-Diversity-antenna-adapter-with-phantom-power-compatible-with-Audi-Seat-Skoda-VW-Citroen-Peugeot-Opel-on-Fakra-radio
I'm yet to try, but needs some box like this to jump from one antenna to the other automaticly for better reception. i don't know if they put some booster (probably because of the blue power wire) but diversity only give's you stability more then range. it's like a redundant sistem.
i don't know what is this blue phantom power cable. is it something RCD330 outputs?
