Flip Camera has blank screen with factory menu
Installed flip camera with factory radio. Everything installed fairly easy.  Latch works, camera flips, screen show the factory disclaimer and menu when put into reverse. My issue is that I do not have an image on the screen. I have double checked all connections and verified continuity. I used an old camera to test the video feed wire at the 6 pin plug with the kit and was able to get an image from that.  Verified continuity from the video feed signal (yellow wire) to the small 5 pin plug on the camera and its good to the plug.  I'm assuming its a bad or faulty camera.  any suggestions? Its been a week since i contacted the seller with my issue and the response I finally received was to  look in this forum. Id like to get this car back together and get my issue resolved as soon as possible. Any help or suggestions are appreciated. Thanks
Newest Member: lannycallaway2 · Currently Online: 13 Guests
