RCD330 Noname 187B: need to hard restart each time for Android Auto to work correctly
Hello! I recently bought an RCD330 from ddren and I was able to install it in my Golf Plus 2010, replacing a RCD510, and I am having one annoying issue that I wonder if other have experienced as well.
When I start the car:
  1. the radio wakes up
  2. I then connect my phone (Pixel 10) with the usb cable
  3. the unit seems to reboot
  4. android auto starts and playback starts
but then, there is some kind of low crackling noise, and the playback cuts out each 5-10 seconds
to fix this, I have to:
  1. hold the power button for 10 seconds
  2. reconnect the phone
and then android auto playback works without issues.
Things that I have tried:
  1. change usb cable
  2. disconnect the old bluetooth module under the passenger seat
  3. remove "media audio" from the bluetooth connection that the radio automatically creates when I connect
has anybody else run into this kind of issue? any hints would be greatly appreciated! 🙂
My old radio also had an aux in input and a connection for old ipods, if that helps somehow narrowing it down.
ps. when I first installed the radio there was no sound, but then I disconnected the battery for 15 minutes and then it started working. I haven't disconnected the battery after I have disconnected the bluetooth module, though.
I have done more investigations about this and these are the results:
1. the issue is with the bluetooth system: when I start the car, the unit wakes up but:
a. if bluetooth was turned on when I turned the car off: the phone screen says "Starting phone"... and stays in a loop. If I connect android auto, it works but audio gets interrupted each 5 seconds, because the bluetooth system is attempting to start itself up and fails.
b. if bluetooth was turned off before I started the car: the phone screen in the unit tells me to turn the bluetooth on, then the same thing happens as above: the bluetooth system tries to start itself up, and causes a loop that blocks the sound (also I can never connect my phone).
The solution for this is to  keep the power button pressed for 10 seconds: the unit reboots, the bluetooth works.
This is however quite annoying to do each time I get into the car, and I have spent a lot of time trying to diagnose this already...
I wonder, could this be a hardware thing with the unit itself?
I managed to fix it!
1. I did the coding as suggested in the wiki
2. I flashed the firmware again
3. I renamed the radio's bluetooth name from the default to something else
4. I removed all emojiis from my contact list (apparently they can upset the mechanism that syncs them) (not sure this did anything.. 🙂 )
now it works!
Hello,
having same issues for few months, what wiki do you mean, and Which firmware did you upgrade ? Mine is 5614 and 9 out of 10 times screen loops at starting phone.
Gr. Floris
Newest Member: lannycallaway2 · Currently Online: 12 Guests
