How to activate the backup camera function and development test mode of the RCD330G Plus
Turn the key in your car to ACC (Do not start your engine) and Plug the VCDS data cable into the OBD interface on the car.
Run the VCDS software on your computer.
1.Click "select" button,
2.Click "56-Radio" button
3.Click "Coding - 07" button
4.Click  "Long Coding Helper" button
5.Selected Byte 3- bit6 "Back-Up Camera installed" ,and then click "Exit" in the menu bar .
6.Click "Do it!" botton.
8.The coding was successfully modified.
9.Repeat steps 1-3 above, Activate development test mode for RCD330 PLUS.
Click  "Adaptation - 10" botton
10.Select "development test mode" from the drop-down list
11. Click "up" Or enter "1" directly in the New value, then click "Save"
12. Click "Yes" and then click "Done Go back". Ending
How to enter RCD330G Plus development test mode
Now you can start the RCD330 PLUS noname 187B and hold down the "setup" button for a long time until the project Engineering menu appears.
Newest Member: lannycallaway2 · Currently Online: 21 Guests
