RCD330 PLUS Desay 187B the latest official firmware 0317(20200303)
Page 1 of 4Next
Free firmwares and technical information.
Thank you!
Spoiler
Sorry, only logged-in users can see spoilers.
This firmware is not compatible with Noname 187B, Only Desay 187B.
Note: Desay SV automotive company has only released two official firmware, one is 0317 (20190625) and the other is 0317 (20200303).
0318(red theme), 0357, 0358 is not the official firmware, but it can be used, but I don't know what bugs have been fixed,
Desay 187B RCD330 plus, the latest official firmware in March 2020 (OS Version: 20200303)
1.The format of the USB flash disk is FAT32. Copy two files to the root directory of the USB flash disk.
2.Press the setup button for a long time until the update firmware menu appears.
3.It takes about 6 minutes to update the firmware.
Press the setup button, then select copyright, and then press the media and phone buttons at the same time. The engineering mode (Chinese) will appear. See the link for translation.
Fix the following bug  (OS Version: 20200303)
1. No image when reversing
2. Incorrect configuration of DDR parameters can cause death, slow response, unable to boot, etc .
3. No sound from FM when adjusting the volume
4. Occasional black screen restart
5. Carplay navigation sound suddenly becomes louder
6, Baidu map response stuck in Carplay state and Carplay response slow
7. Samsung S7, connected to Bluetooth, but after hanging up, it always plays the ringtone of the mobile phone
8. Radio displays "temperature is not within the working range" and automatically shuts down
9. Fast-charging mobile phones cannot connect to Baidu CarLife
10. USB / SD does not read: Insert USB to display "Loading USB", insert SD to display "Loading SD"
11. Black screen (Kernel failed to start)
Hello, have you a Update to German Language and Android Auto for Desay 187B?
Android Auto could not be installed on Desay 187B until now.
German should be able to write through TTL, need to open the seal, open the unit. Sorry, I haven't got this file yet.
hansb4 has reacted to this post.
hansb4
when it will be free download 🙁
Quote from wicky_cheong on August 7, 2020, 10:18 am
I only charge $3. Only 4 people paid in total.  Thanks to those who support me.
I want to collect some more money for the rent of this website
Bro, i donated $3 to your paypal today 10 Aug 2020, but i forgot to write down my email, can you check it ?
my email : *****
Thank you for your support, I have sent to you, thank you!
Bro, after completed update, unable to go in to back end panel with press Media+Phone together, any idea ?
Method 1:
After the upgrade is completed, please click "Settings", select "Copyright"  and then click the "media" and "phone" buttons at the same time, the project menu will appear. If it is unsuccessful, it means that your Desay 187B is an earlier version. Please use method 2.
Method 2:
After the upgrade is complete, please click "Settings", select"Copyright" , and then long time press and hold the "media" and "phone" buttons  until the project menu appears, about 30-50 seconds.
If neither method 1 nor method 2 succeed, you first activate the developer mode of the system with VCDS cable. Watch this video.
Method 2 was perfectly work ! Thank you so much for your guiding !
Page 1 of 4Next
Newest Member: lannycallaway2 · Currently Online: 23 Guests
