Desay 187A brick fix via USB to TTL
Desay 187A RCD330 plus, because of its outstanding functions and playability, is liked by many friends. Its operating system is Win CE 6.0, and you can access its desktop system by upgrading firmware. Like other windows operating systems, you can install software and copy, paste and delete files under Windows interface.
DOWNLOAD
Spoiler
Sorry, only logged-in users can see spoilers.
Some friends have made some mistakes in the process of upgrading or deleted system files, some of them are human-made, some of them are caused by unstable storage devices. The head unit becomes a brick.
There are two main situations,
1. The system stops at the public boot logo interface and restarts at a fixed time interval;
2. The system prompts that upgrading is in progress, the scroll bar stops for a long time, and there is no other response.
You can connect to the main board of Desay 187A through USB to TTL, use putty software to enter its underlying system, and fix it.
Run the putty software, set the correct COM port and rate (115200). The port of COM port can be viewed through the device manager.
When the head unit is turned on, the window on the computer points to putty, and keeps pressing the space bar,
It will enter the boot menu.
[1] Upload Bootloader
[2] LAUNCH existing Boot Media image
[3] Update image via USB
[4] UPDATE image from SD/MMC card
[5] DOWNLOAD image via USB RNDIS Ethernet
[6] Reset TOC
[7] Erase MBR
[8] Config menu
[9] Debug Boot Media
[A] Storage Menu
[D] Desay OEM Data menu
[E] Erase boot media
[M] Config New Feature for MMC v4.3/4.4 card
Selection: 4
Start rewriting system
Then you can update the firmware again and enter WinCE desktop
When I did this, I still cannot get back the HU. Attaching the log file from Putty.
This is done now. Thank you for the help ddren.
Hi will this work on the Lemonshark 187B? Or can someone point me in the right direction?
After taking my unit apart the board does not seem to have the same layout
hi
when try install image need password for login
thanks
Quote from gabbara on December 1, 2022, 12:09 pm
hi
thanks
Hi, have you solved? I'm the same problem
Hi when try install image need password for login.
Hi, can anyone tell me what I'm doing wrong?
Newest Member: lannycallaway2 · Currently Online: 20 Guests
