The difference between high quality and Ordinary quality gateway emulators
High-quality ISO Quadlock, it is split ISO quadlock, a much better product, and it can jam the CVBS plug. Perfectly. It's stronger.
1. If your car is MFSW with 8 buttons manufactured before 2009, there will be battery drainage problem when installing rcd330 plus, and some buttons will lose function. This CANbus simulator can solve the problem of battery drain and MFSW bottons problem.
2. If you don't have MFSW, just the battery drain problem (VW 2005-2009), It can also solve this problem alone.
3. Some Volkswagen( 2005-2009 ) can be also solved the battery drain by replacing the gateway.
Usually the model of the gateway is before 530H, including 530H itself (the beginning of the gateway is 1K0 or 3C0),There will be battery drain
https://www.ebay.com/itm/183723468576
4. If your original head unit is RCD510, this emulator is not required to install RCD330 plus.
5. If your car MFSW is 12 button, you don't need to install this simulator.
Newest Member: lannycallaway2 · Currently Online: 20 Guests
